Old 01-24-2011, 11:26 AM
SmallHaul's Avatar
Default Re: 4 conductor (or more) Slip Ring options
Originally Posted by JAMMER View Post
Why don't you make one your self the only thing it does stop the wires from twisting. Get a tube solder it to the base run your wires through it to the top . let the cab spin around, it make the hole bigger than the tube so it will spin with out turning tube or the wires. Ed
I want continuous rotation and that requires contacts/sweepers for each conductive wire. If you just had a wire through a tube you would have to remember how many times you went one way or you would eventually get it wound up too many times one way.
Scott
"No load is too Small"
