Old 01-24-2011, 12:29 PM
modelman modelman is offline
Default Re: 4 conductor (or more) Slip Ring options
SmallHaul-most of the slip rings on E-bay are going to be 2-amps because the wires are "super tiny" and that is all they can handle. Here is a place you can get about any kind of ring you want but they are "very pricey"!
http://www.moog.com/products/slip-ri...through-bores/ .
This is just the thru-bores. You can look and see what you need.
They are in Blacksburg VA.
Old 01-24-2011, 12:55 PM
I'm using the model 4598 6 10amp conductor on my dragline. It's way over kill since I'm drawing no more than 1a-2a for my whole machine. That may change when I add some lighting.
The slip ring you missed was under the guys table in a box but wasn't priced when I looked at it. It had about 24 conductors probably 1a each. I would try one of those cheapo ones and see what they can handle.
