Old 04-28-2022, 03:48 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: Build an Excavator from Scratch
A medium issue I've found was the unwanted contact between the superstructure and the undercarriage regardless all the ball-bearings.
So i've added another dedicated flat bearing from igus. called "iglidur"
A .5mm thick plastic, easily cutable with a sciccor.
Glued direct onto the stainless steel with a combination of loctite 770 and 401.
After deburring and polishing the sprocket a first test
Then the optical improvement of the undercarriage begins
The front inner View is now this
And the side view before
and after the improvement
Regards
Ralf
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
