thanks frizzen.
my last post looks a bit breaked. I'm sure i've wrote it much longer. Anyway. edit: I've found that the degree character has broken the post. so i'll ignore it from now on ![]() together with a 90 degree guide for the lever sheare ![]() and a parallel guide for the press break ![]() i'm able to made reproducable cuts ![]() and after bending ![]() more cuts ![]() ![]() i'm able to make exact angles with 7mm length ![]() after solving a puzzle the frame of the cabin is done ![]() ![]() ![]()
Regards Ralf Last edited by pufferfish; 05-25-2022 at 03:44 PM. |
some impression from the cabin
![]() ![]() ![]() The stick are display holders ![]() ![]()
Regards Ralf |
cabins upper guard
3mm stainless rods ![]() welding setup ![]() ![]() ![]() operators joystick. freehand cutted from some stock aluminium using a ball vise and a foredom hanging motor. ![]() looks similar enough as little details on the chair. ![]()
Regards Ralf |
