thank you, zabco.
---- The cabin gets a bit more interieur and a fire extinguisher. All windows are in and the cabin is installed on the under construction. ![]() ![]() ![]() The complete ensemble is dismountable in seconds to reach on the ballast sections. ![]() The cabin is done ![]()
Regards Ralf |
I really am amazed at how quickly you complete all this fabrication! Very nice!
Thank you.
Fast? This build is running since eight Months. But the end is nigh ![]() The Cabin is done and the work on the Hull has started. Unfortunately I'm not able to "metal shaping" with a shrinker/stretcher/english wheel in a proper way. So I've decided to make the back not really round but in five parts. ![]() After two hull panels (the back and the small part behing the cabin) I've mocked up all the parts to check the proportions. I like it so far ![]() ![]() ![]() ![]()
Regards Ralf |
The superstructure and the undercarriage are now connected.
The electro block has moved from vertical ![]() to horizontal ![]() to get room for ballast, if i need some ![]()
Regards Ralf |
