Very nice build. Impressive skills!
Thank you.
I'm a fan of functional gimmicks. So i've spend the last two days in the shop to make a remote controlled ladder for the operator. ![]() ![]() ![]() I think, the operator needs some handrails ![]()
Regards Ralf |
I think it
Todays work was a repair of the stick cylinder. Before the final assembling i've made the mistake to pull the rod complete to the end. During normal operations this never will happen due to the geometry of the stick.
At the end of the cylinder the piston collides with the oil input flange ![]() thereby the piston seals get damaged ![]() To open the cylinder i have to loosen the head. Sealed with loctite 542 thread sealant it just needed some hot air ![]() After replacing the piston o-rings and refilling the oil then thread sealant is applied ![]() Now I have to wait 24 Hours before the glue is cured.
Regards Ralf |
24 hours later: The repair was successful.
![]() The stick holds his position. After this I've made a last stress test. Mounting all the 20kg ballast as counterweight ![]() And a little mandrel press was the lifting object ![]() her weight ![]() and finally the test. lift and hold. passed. ![]() I'm very satisfied with this result. After a holiday the final work on the hull begins...
Regards Ralf |
Detailwork.
A rough sawed ![]() and fine filed patch for the cutout of the ladder lever ![]() A door handle ![]() and handrails complete the second of four parts of the hull. ![]()
Regards Ralf |
Hi. Nothing new due to a vacation, but today i have a first training session for my eye hand coordination.
Works a bit better but still much to learn A short clip https://vimeo.com/727432466
Regards Ralf Last edited by pufferfish; 07-06-2022 at 12:02 PM. |
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests) | |
