Old 06-09-2022, 04:00 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: Build an Excavator from Scratch
Thank you.
I'm a fan of functional gimmicks. So i've spend the last two days in the shop to make a remote controlled ladder for the operator.
I think, the operator needs some handrails
Regards
Ralf
Old 06-09-2022, 06:49 PM
Tgrzes Tgrzes is offline
Tgrzes is on a distinguished road
I think it
Old 06-10-2022, 02:59 PM
Todays work was a repair of the stick cylinder. Before the final assembling i've made the mistake to pull the rod complete to the end. During normal operations this never will happen due to the geometry of the stick.
At the end of the cylinder the piston collides with the oil input flange
thereby the piston seals get damaged
To open the cylinder i have to loosen the head. Sealed with loctite 542 thread sealant it just needed some hot air
After replacing the piston o-rings and refilling the oil then thread sealant is applied
Now I have to wait 24 Hours before the glue is cured.
Regards
Ralf
Old 06-11-2022, 09:47 AM
24 hours later: The repair was successful.
The stick holds his position.
After this I've made a last stress test.
Mounting all the 20kg ballast as counterweight
And a little mandrel press was the lifting object
her weight
and finally the test. lift and hold. passed.
I'm very satisfied with this result. After a holiday the final work on the hull begins...
Regards
Ralf
Old 06-13-2022, 02:59 PM
Detailwork.
A rough sawed
and fine filed patch for the cutout of the ladder lever
A door handle
and handrails complete the second of four parts of the hull.
Regards
Ralf
Old 07-06-2022, 12:00 PM
Hi. Nothing new due to a vacation, but today i have a first training session for my eye hand coordination.
Works a bit better but still much to learn
A short clip
https://vimeo.com/727432466
Regards
Ralf
Old 07-12-2022, 03:25 PM
At least, the Beast is done
The official pictures of my first scratch build of an excavator in 1/10 scale.
Thanks for watching
Regards
Ralf
