Old 06-13-2022, 03:22 PM
pufferfish pufferfish is offline
pufferfish is on a distinguished road
Default Re: 1/10 Oilfield Truck Foremost Delta 3
The front suspension are leaf springs. For this monster no springs are buyable.
First step are the holders for them.
Aluminium 25x10mm
some holes
sawed with the small tablesaw
ready for the springs
the springs are from
these tapes are easy cutable with a manual metal shear
drilling is more challanging, but at least its done
Bending and preforming was easy with heat. Spring steel losts his tension and you can form the eyes simple with pliers.
Preforming needs a support with screws in the right distance.
heat up and when its hot enough you can see the lost of thetension . after cool down the spring holds this form but is still springy.
mounted
with more progress on the cabin, some leafs will added.
Regards
Ralf
Old 07-05-2022, 02:55 PM
hi. i'm back from holidays
Next step was the articulated joint:
Two pieces of aluminium marked
slotted
milled
holders
works fine so far
as you see, at this stage the plan was a 4x4.
Regards
Ralf
