Metal forming & tools If it bends,twists,welds,cuts & turns metal.Post it here |
0.9mm, .035" 20 ga 1008 steel. Butt joint, fusion weld at top only, minimal surface prep. Cut perpendicular to weld seam. Shown through 5x microscope and raw camera capture. Small shiny things are really hard to take pictures of.
Power level: 66J ![]() ![]() Not full penetration. Joint is homogenous. Very little heat discoloration on bottom Power level: 100J ![]() ![]() Full penetration. Has a slight stripe thru the joint. Bottom shows heat effect |
Currently Active Users Viewing This Thread: 71 (0 members and 71 guests) | |
