Old 12-23-2022, 01:09 PM
Default Re: Wooldridge 1940s Bottom-Dump Truck
Found a video about program Differential Thrust planes that suggested starting setup mix Offset at 50%. I believe on this, that should slow down the rate of steering.
Yeah, you probably don't have to worry as much about this thing rolling over when you give it a turn command if things are a little TOO touchy.
