Old 12-26-2022, 08:42 PM
Default Re: Wooldridge 1940s Bottom-Dump Truck
Yes, it's been getting some programming & shake-down runs with electrical stuff just lashed to the outside. Overall it runs pretty well. Still trying to teach an 'Airplane' TX to speak whatever language this does.
If i have ch 1&2 slaved 100% together as Drive, how do i slave 2&1 together as Steering with a lower differential rate?
Hitch to Wheel distance is a LOT shorter than the Track length on a Bulldozer, and tires are taller than drive sprockets, so turning happens RIGHT NOW!
I probably could have dropped another gear-ratio lower, or gotten better Escs. My hitch needs work. The tires are ancient. I need to build a big battery pack. I'm unsure what i'm doing... But it works.
