Ok....I'm kind of new at scratch building small detail pieces with brass stuff so some of this may look a little amateurish to some of the builders ....
A builder on another site was kind enough to send me some rear view mirror files these are the ones I chose for this truck cause I liked the art deco looking detail on them ![]() These are just remixed spring hangers for the WPL springs and axles they drop the axle about 1/8 of an inch... I screw one end down and let the other slide in this mount. ![]() This is just a frame spacer for the rear if you just want a flush rear frame...I either use WPL self tapping screws made for plastic or run a 3mm bolt thru the top or bottom of the frame rail, threading the aluminum to hold the screw this stops the frame from spreading or the block from slipping out. ![]() This crazy looking thing is my mount for the bed lift actuator, the first one I made and installed didn't have any way for routing wire past it for lights or anything else... so I made some space... this piece doesn't actually take all the thrust from the lift actuator, there is a 3mm rod all the way thru it that goes thru the frame this just supports the rod and takes the flex out of it... ![]() These 56 cabs didn't have anything inside ...heck they didn't have a windshield...so I remixed a steering wheel and mount. For the windshield I cut clear plastic from a Diecast Masters box and bent it to the shape of the cab and hot glued it in...( sorry no picture of that) ![]() This is what it looked like with the mount before I cleaned it up and added some paint. ![]() This is a test mounting of the cab after paint.... you can see the running boards/battery box steps... ![]() The cab sides should be straight but they taper back to the rear of the cab, this made putting running boards on it a little tough. Getting the taper angle was giving me a hard time so I just squared up the steps with the side of the frame, not the exact look I wanted but .... I wanted those boards on the bed sides... so I made some up... I believe these are scale 2x12s... ![]() The supports should be about a scale 6 inches across ![]() I did the bed in a semi-gloss black I didn't want it super shiny. ![]() So here are a few shots of it in the sun for the first time. ![]() ![]() ![]() ![]() I did 3d printed mud flaps just to try them plus I wanted some kind of logo...I printed these in white, then shot a heavy coat of primer on the back to fill the lines a little. Then I sprayed them flat black, let that dry over night and dabbed blue in the low spots in the oval. After that dried over night I carefully sanded the raised parts of the logo to expose the white underneath, I tried painting them white by hand but it looked like crap.... This came out way better. One final shot...I'm really happy with how this one came out.... I learn a little more each time I do one ![]() I think this truck needs a friend..... ![]() |
Currently Active Users Viewing This Thread: 41 (0 members and 41 guests) | |
