Go Back   RC Truck and Construction > RC Truck's Odds and Ends. > Static Conversions
Static Conversions This is the place for all your Bruder cab and trailer conversions.
Old 03-30-2023, 12:09 PM
Default Re: 1930s dumptruck - Nylint
Thanks, I'm pretty happy with wheel size now. Fenders aren't as stuffed, and should be a lot easier to keep from rubbing with suspension travel.
Yeah, i know the split-rim wheels i work around have something like a 15psi (temperature-adjusted) window where you can change nitrogen pressure while it's installed on axle. If they're out of range on the chart, gotta vent it, pull the valve core, and send it out for overhaul.
Green & Black might work. I'm not real sure on a color plan
