Old 04-02-2023, 12:17 PM
Default Re: 56 Ford Semi
I've got the 5th wheel on and motors mounted
I used a mounting plate I found on thingiverse for WPLs it was a little small to my eye so I remixed the mount to fit a LESU 5th wheel... yeah it's a little large but I think it will make getting a trailer on it easier....I can always fall back to a smaller assy if it doesn't work as I hope...
Just a mock up.
After I looked at this I decided to move the 5th wheel up to just ahead of the rear axle center line....don't have a picture of that
I wanted to try a dual motor configuration.... the bottom mount is the original from thingiverse... the top is after I remixed it to move the motors closer to each axle..
the motor shaft is 4mm and the axles are 3mm so I drilled out one end of the drive shaft.. I tested it on an older type shaft first...
Here it is mounted... yeah it hangs down a little more than I like but once I get the fuel tanks and steps on you won't see it...I hope
These are 6v 500rpm motors the axles are 2:1 giving me about 250rpm at the wheels
I'll start getting some details done this week.... it's almost time to get out in the yard and garden
Currently Active Users Viewing This Thread: 22 (0 members and 22 guests)
