It was pointed out to me that i didn't include several measurements from my Cable Drums...
1" rod stock, clean up OD 0.250 long shoulders at 1" OD 1.5" OAL 0.750" diameter cable bed (1/8" deep) 1" long cable bed Center drilled for whatever mount system you're considering Bonus points, Lightly score for alignment of servo horn OD or screw holes ![]() Cable bed of spool is the last gear ratio of a cable machine, like changing tire height on a car. Diameter x 3.14 = line pull per revolution. < 0.750" x 3.14 = 2.355" line per rev on base wrap > Line pull per revolution x RPM (or look up Servo transit speeds, convert angle to 360...) < 0.2sec @ 60 deg... 0.2 / 60 sec = 300, 60 deg transit = 6 per rev, 50 rpm = 117 inch of line per minute max speed > so i'm running channel EPA cranked way down. Bigger spool = faster pull / less torque Smaller spool = slower pull / more torque Dragline fairlead (suggested prior art) https://patents.google.com/patent/US3006608 I just use some redirect sheeves to catch and pull the crowd back inline to get through the boom in a Z path
What do ya mean "Cars are neither Trucks or Construction"? It's still scale, and i play fairly well with others, most of the time... Last edited by frizzen; 10-12-2023 at 01:04 PM. |
