A fabric glue such as Aleene's Tacky glue might an option for the straps. It won't be as fast since it takes a while to dry, but it also won't try to curl up like the heat shrink does. You could always use a small drop of CA glue with the Aleene's. The CA is used to tack the straps together while the Aleene's dries.
Thanks for the tips on gluing, I'll put that on the to-get list.
And I just found an off-shelf item that is almost identical to the brass hooks and it only needs to be bent to shape. And very economical, too. |
Currently Active Users Viewing This Thread: 25 (0 members and 25 guests) | |
