Old 03-22-2024, 01:45 AM
Default Re: 1/10 caterpillar 140h motor grader 3d printed
Originally Posted by ddmckee54 View Post
Oooooo... those look right at home. Any foam inserts in those tires?
they do come with inserts, these are 2.2 tires, luckily, i designed the rims to be 60mm diameter which is what 2.2 tires come with, and with a bit of stretching when you put it in... i might add another 10mm thick of foam to make it more solid and beefy...and also, to push the tire beads towards the rim lip, im pretty sure it will get a lot heavier when the electronics and battery are installed...and i dont want it to look like a flat tire when sitting still.
Old 04-15-2024, 07:46 PM
Update on the build... i have a driver, yay... the tires also i think is a good fit and quite realistic...
