It was finally time to get the chassis moved off the mockup axles. Decided it needed some wpl 'potmetal' axles, and might as well get a set of brass Differentials instead of the steel Spools those come with. My thinking was that a Box truck probably needs turning radius more than 4 wheel traction or durability.
Get in the zone, Advance toy parts Oh oh oh, oh Napa. We didn't need liftgate service, so they were willing to send a parts-runner out to the garage. ![]() These brass Differentials felt crunchy, so i spent a while pushing inward on axles while rotating to help wear in the gears. I plan to run them for a while, then open to clean and lube. Everything needs to come apart for threadlock once it's more final anyway, so that shouldn't be a problem. To make up for the larger housings for spiders, these diffs come with a shorter pinion than used on wpl spools. --- I've been looking for a D-wheel dually conversion rim with the convex face. Chevy and GMC grille https://www.etsy.com/listing/1599115...original-style https://cults3d.com/en/3d-model/gadg...conversion-kit https://makerworld.com/en/models/374...42?from=search Rally wheel center in d12 structure https://youtu.be/l5PnA-2UCSM?feature=shared m2.5x20 hardware to stack wheels https://www.thingiverse.com/thing:6174132 Squishy tire with d12 steelie profile wheel
What do ya mean "Cars are neither Trucks or Construction"? It's still scale, and i play fairly well with others, most of the time... Last edited by frizzen; 04-15-2025 at 08:55 PM. |
Currently Active Users Viewing This Thread: 12 (0 members and 12 guests) | |
