The drivetrain is pretty conventional using off-the-shelf components. Front axle is your basic Tamiya type passive, and yes, that means I'm mixing ~1:14 manufactured and ~1:12 printed parts, but I don't think it's noticeable to the naked eye. (If you're breaking out the ruler or calipers to my builds I've got bigger issues =)) Rear axles are from Integy, a type I've used on other builds. They're a bit blocky, but I like that the parts are interchangeable, ie the through axle is the same as the end axle, just with a blank diff cover instead of one with an output in it. Same for the steering axles, so for my 10x10 HEMMT I had two steer axles in the front plus one in the back. All the same axle means designing the suspension is easier.
![]() Front suspension is leafspring, using the Chinesium "D90" springs as I had some on hand. Rear suspension is linked, which always annoys me and yeah, maybe I shoulda done airbags, but the axles come with links. Did require custom link lengths, but was able to print new center tubes and reuse the rod ends. Getting the link lengths right always drives me nuts, and this build was no exception. I really shoulda done leaves or leaf+links like the Lesu pre-made box, but the Integy kit came with all these links so it's another "How hard can it be?" moment. The rear driveshaft was a nightmare; ended up just sleeving some square brass tube inside U-joints. Soldered the ends of the tubes so they didn't squish under the setscrews. Also always seems painful to find shocks which have enough rebound for my taste but fit into the desired space. Both front and rear use Chinesium shocks, but with new much stronger springs on/in them. (Particularly in the rear as I know that's a horrible shock angle, but again, getting everything to fit was a major pain in the watoosi.)
I mean, how hard can it be? Last edited by dremu; 03-17-2025 at 05:41 PM. |
In the past I've used a dual-extruder printer, which allows two colors, but they're a pain to keep the extruders aligned. Lately been using a Bambu printer, which only has one the one extruder, but can switch colors mid-print. There is a performance hit if you do it a lot and/or have many layers with multiple colors, so it takes careful planning. Otherwise a piece that prints in 30 minutes in one color suddenly takes four hours with a coupla colors :O The bumpers and brushguard did well for this because there's only a handful of layers with the colors, mostly the silver. The inlays are "transparent" (I'd call them translucent, whatever) red, orange, and white, so the LED's behind them shine thru.
I mean, how hard can it be? |
Top of the cab gets lights in multiple pieces
The orange then glues on in front. Horns are actually genuine Tamiya and mostly look right; 1:12 and 1:14 scales are close enough to fudge mostly. Headlights are just switched via the RX, some nice bright "straw hat" shaped 8mm's. Turn signals and the rear lights are driven by an Arduino Because in RC, I find rarely is there a problem that can't be solved with an Arduino =)) The front turns actually annoyed me, as I couldn't find T1-sized LED's I liked, or otherwise make it bright enough to just use one LED, so there's that stupid tube with an LED on each end. I may change them up to a WS/SK2812 "NeoPixel" style once I get some in that are clear vs frosted. Anyway, the Arduino gets the iBus data from the RX, and decides if it's turning left or right (in which case it blinks the appropriate turns), backing up (reverse lights), moving forward (turns off brake lights) or stationary (turns on brake lights.) There's also a switch on the TX for hazards which blinks both sides' turns. Some printed greebling; there's also some wheel chocks somewhere that I printed, and then some stuff from AliExpress that's just SO ADORBS because it's SO TINY but the ratcheting straps and loadbinders actually work! Pix those with the trailer later. And then the regulatory cat scan Duke Leto Atreides II has to check the thing out and decide whether to be frightened of it or chew on it.
I mean, how hard can it be? Last edited by dremu; 03-17-2025 at 06:14 PM. |
So that's how it sits as of now.
Yeesh that is one ugly fireplug of a man. Next up is trailers, because what good is a semi if you have nothing to tow? More to come.
I mean, how hard can it be? Last edited by dremu; 03-17-2025 at 06:05 PM. |
Currently Active Users Viewing This Thread: 21 (0 members and 21 guests) | |
