Old 08-17-2025, 04:28 PM
Blender's Avatar
Blender Blender is offline
Default 1:14 BMG C308 Excavator improvements
Been eyeing the modest priced, poor performing excavators for years. Using just the shell has been my plan as an economical way to build an excavator without making every single part myself.
Last year the C308 was released. Ordered it blind with only two small pictures and vague dimensions. Upon arrival the machine looks great. Lots of detail, lots of metal and very close to actual 1:14. The bad is the hydraulic system (as expected) gets blazing hot even digging air and pulls over 9A. Run time would be under 20 minutes. Valve block is not too bad. Respectable fine control, modular type for extension. Hydro lines are all 2mm OD but significantly smaller ID than SMC line. Chokes out the bucket and stick cylinders. Machine is very easy to take apart. Blade is electric and Aux hydraulics are fake with solid rod hard lines. Only 3 spool valve.
As factory built.
Short version of the heat is the stock pump spins way too fast. Included motor doesn't have the torque to run slowly. Swapping the motor allows better starting torque, but the internal leakage inside the pump becomes noticeable. System holds at 100psi with very little flow. At pump speed >3k rpm then flow increases significantly, and pressure builds to actually open the relief valve. The combo of pressure and flow increasing together makes everything jerky especially with the tiny bore cylinders. 9A through the stock motor is a lot of power which built a lot of heat.
The fix: leimbach pump with my own outrunner and reservoir similar to my telehandler build. Valves are ScaleArt since I wanted to try them. Boom and stick cylinders were swapped to Magom 10mm to increase power and reduce speed. Lines were all replaced with good stuff in 4mm and 2mm OD flavor.
Pocketing out to make room.
new slew system. I liked the servo drive, but it's too big.
skip a bunch of steps, and the hydraulics are working good with around 3A peak current draw. Stays cool. Stock tank was a really nice billet aluminum piece. Walls were too thin to bore out for the Leimbach. Replaced with a SLA printed tank.
Old 08-17-2025, 04:43 PM
Blender's Avatar
Default Re: 1:14 BMG C308 Excavator improvements
getting rid of the yellow paint took weeks. Livery will be Sunbelt Rentals to continue my theme. Boom bracket was rebuilt to better attach to superstructure. Original would rock under load.
sat in pieces for a couple weeks. Maybe I remember where everything goes.
laying down some color. Boom needs additional coats which is why it looks too yellow. Weird thing is the housing for the slew bearing is actually plastic. If it's an issue I will make a beefy replacement.
adding a Lesu 270 deg hydraulic swivel. My main use for this machine is to place 1:14 jersey barriers and this is a must-have. Simple brackets will dangle this from the quick coupler. The Kenco barrier gripper will be permanently installed. This machine won't ever dig.
Old 08-17-2025, 06:17 PM
Interesting, nice upgrades. Great improvement in pump performance. Were the boom parts cast also or assembled from pieces?
Old 08-17-2025, 06:38 PM
Blender's Avatar
Boom and stick are machined aluminum as two pieces each. Left and right are a press fit together with no external fasteners. Mostly hollow.
Old 08-24-2025, 07:45 PM
Blender's Avatar
Rebuilt all the hard lines with thinner wall brass for better flow. Surprisingly the soldering iron did better work than the torch. Ran out of fittings to do lines on the stick.
Two axis swing above the swivel. Top half of the Kenco is redesigned to interface. Can already tell the soft lines are going to influence the hang orientation.
New guy already ruined the paint on the counterweight. I'll let it ride until the weather is nicer to repaint.
Old 08-25-2025, 06:09 PM
Those new lines are going to look great. Gotta watch those new guys like a hawk.
Old 08-30-2025, 02:05 PM
Looking good Blender.
Old 08-31-2025, 05:47 PM
Blender's Avatar
Thanks for the kind words.
Plumbed everything. New hardlines worked great. No leaks and I can tell the cylinders are a little faster.
Been dreading the electronics on this machine and the telehandler. Both are a very tight fit. Ended up unwrapping the pump ESC to replace the wires with reasonable sizes. Bummer they don't make low-current escs with the same telemetry features.
Built the top half of the barrier lift.
Made a slightly smaller reservoir to prevent to motor from rubbing against the pack.
theorizing placement. Machine has 5 ESC: Pump, two track motors, slew motor and electromagnet for barrier lift.
Looking kind of possible. Wired it all up and the two double-Channel ESCs are not acting right. Gotta dive back in, or switch over to the tried and true fingertech "tiny"
animated Gif of swivel. Speed is about right.
Old 09-01-2025, 08:36 PM
Animated GIF? How-U-Do-Dat?
Old 09-01-2025, 08:51 PM
Blender's Avatar
Record a video on my phone. Email/transfer to PC
Upload video clip to https://www.freeconvert.com/convert/video-to-gif and fiddle with settings until it looks ok and not a huge file.
Host on imgbb as if it's a still picture.
Old 09-01-2025, 08:56 PM
Blender's Avatar
Also all my Sunday work was for nothing. The dual ESCs regularly go into calibrate mode and lose settings. Blink code doesn't match the instructions although I was able to reset one correctly. Not worth the headache.
Old 09-02-2025, 11:55 PM
What's your definition of "not a huge file"?
Old 09-03-2025, 09:38 PM
Blender's Avatar
The one here is 12MB. Pretty big, but OK. Ideally under 4MB and I'd consider 15MB an upper limit. Also depends on the image host you're using.
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Krewmember
