Old 01-30-2011, 03:14 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: Sterling Dump
10,500 rpm should be fine if your feed rate is OK for the .015" end mill. 6500 rpm for the .250" is a little high but again OK if you are using any type of cooling. I noticed that you either have air or coolant lines for the tooling. If you use either, you should be fine.
That is one of my problems. No cooling of any type for my mills. Need to get an air compressor and start running air lines!!
Old 01-30-2011, 05:16 PM
Heavy Metal Heavy Metal is offline
Heavy Metal is on a distinguished road
Thanks Lynn. VERY helpfull. I do need to figure out what feed rate an .015" and .025" end mill can handle as well as safe max depth. Any experience there? Can I do .02 in one pass?? These are stub end so mill ends only .063" long w/ .125" shafts. I'll be doing some reading but always nice to find someone that already knows the answer!
Yes, I run an air coolant setup. Actually came with the mill - I bought it second hand from a custom cycle shop that had upgraded to a Tormach (drool). Little gizmo makes some pretty cold air! Coolant mist systems look pretty nice and seem affordable. Messy I suppose and would require air compressor anyway.
I know you are right about 6500 RPM being too fast (at least for the .25"). Maybe I left it there because I'm was always working in the 0.125" range. I better do a little homework so I don't dull my end mills running 'em too fast!
Joe, I'm not a pro either, but what you do sounds about what I do. I usually just go by feel (manual milling, no CNC for me) and how the cutter sounds...
...I almost always spray some light oil onto the material I am working with, by hand using a spray bottle, and the end mill.
Nate - Glad I'm not the only one! It's amazing how much manual milling helped me understand what works and not. Can't "feel" anything w/ CNC and the math is only good so far anyway. I jumped straight in to CNC having never milled anything manually or otherwise. After a week or two messing around I sat in the garage one night running the Taig by hand (no graduated hand crank but does have big beefy knobs on it) and that did me more good than a weeks worth of reading books and web sites. Any specifics on the oil you are using in the spray bottle? Sounds like a good idea.
Old 01-30-2011, 07:10 PM
ihbuilder's Avatar
joe nice work that grill is right on the well drilling outfit my 1 friend works for just got a couple of those trucks 2 w/a flatwater body(flat bed on top of a water tank ) and 1 w/a drill As for feed don't push it , the slower you move the table the better finish you'll have . I'm doing stuff manually and I go by feel . most times on my lathe I'll hog it down with the power feed then do a finish pass by hand to get a much slower feed speed . I'm starting to learn cnc but it is still a little greek to me yet .
Steve
Old 01-30-2011, 10:43 PM
Few updates here. Mom and Dad stopped by today - they found some pictures of the Sterling my Pop used to drive. He was pretty excited seeing the old pictures and looking at what I was working on so that was pretty cool. Pretty good looking machine too. Don't think I can do white wheels though...will look way better w/ alum wheels and dual stacks.
Showin' off the box in action...
Did some more work on the grill. This is the first prototype of the lower grill and turned out pretty good.nice. If all goes well the final part would not have the big oval cut out...just cut down in relief with raised word STERLING. Then I would paint the relief section black.
That's probably it until next weekend...busy days ahead. Thanks again for the kind words and all the machining tips. Joe
Old 02-06-2011, 04:51 PM
sneaky-pete's Avatar
sneaky-pete sneaky-pete is offline
Master A-Modeler
sneaky-pete is on a distinguished road
Nice work on the grill....WOW!
Troy
Old 02-06-2011, 05:37 PM
SmallHaul's Avatar
Wow, nice finished product!
Scott
"No load is too Small"
