Old 08-19-2010, 10:31 PM
FreddyGearDrive's Avatar
FreddyGearDrive FreddyGearDrive is offline
Admin RIP FGD 2-12-59/12-19-11
FreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the roughFreddyGearDrive is a jewel in the rough
Default Re: Driven front axle options?
BINGO!That's the exact order.
SmallHaul,the carson front diff is like $200.
For the same price you can get this.
But! Now you have to buy a set of semi rear diffs to match the front. The rear diff that comes w/the front is two wide for semi. But you can't beat the look of these babies.
The carson is like 2mm narrower than rc/channel.
The carson I was purchasing from pmd. But surf a little & you can pick them up a lot cheaper.
Hope this helps!
FGD
Old 01-02-2011, 03:24 PM
Snochaser's Avatar
Hope this helps!
FGD
So are these Carson axles?
Old 01-02-2011, 07:21 PM
Snochaser,The aluminium one are R/C Channels.The plastic one is the carson.
