this is what im getting http://www.servodatabase.com/servo/springrc/sm-s4315r
![]() Torque: 4.8V: 201.4 oz-in (14.50 kg-cm) 6.0V: 213.9 oz-in (15.40 kg-cm) and are factory 360 robotic servos with J-channel connector. gotta watch some are a square 4 pin connector that i haven't seen before.
The bucket is made. It is not perfect but, it is the first time I ever brazed aluminum. I used the aluminum weld sticks from harbor freight. I sure learned a lot using it and will be able to do a much neater job the next time I use it. The ears at the back of the bucket will have holes drilled in them for mounting the rear pivot arm. I am surprised how heavy it is now that it is all welded together. I'll probably eventually make a another one out of thinner aluminum and make it neater.
