Old 01-31-2011, 03:20 PM
Dreamweaver's Avatar
Weaver Of Dreams
Default Re: my first semi build (dump)
Looking good Jason. I'm not sure if you know this and just have not done it jet, or if you are scratching your head trying to figure it out.
To get the roof to fit right from the point you have it, you will need to cut it in half from left to right and add a filler piece.
Good job tackling that big of a modification on a shell..
-Mike
Mike "DREAMWEAVER" Johnson
Old 01-31-2011, 08:46 PM
DieselKid's Avatar
DieselKid DieselKid is offline
DieselKid is on a distinguished road
Coming along beautifully Jason! Starting to look like a real brute!
-Alex
Whatever floats your boat, just as long as it doesn't sink mine...
Old 01-31-2011, 09:01 PM
chaseracer's Avatar
-Mike
thanks guys, and thanks for the great tips Mike, although I did plan to split the roof to make up the gap in front window pillar but is was getting late last night and I got lucky with all my other cuts , so I didn't want to press my luck
hopefully more to some soon, I really need to make time to work on this.
Old 02-09-2011, 01:17 AM
chaseracer's Avatar
next update, well in order to make this dump dump, it needs power to move the screwdrive. the common way is to hook seperate motor up to the screwdrive controlled with a second esc and channel, well I wanted to try something different, so with some ideas in my head and friends like Redbull with more ideas and tools, then me. I spend the day at Redbulls (mikes) sunday, and we worked on making a pto style system off the transmission. in order to make this work I needed to make a second shaft come out the back of the tranny. so it would provide power for my pto.
stock tranny.
so the idea is that the 3 speed tranny will operate the pto, meaning I don't need another motor mounted on the truck. so order to do this, we need to make a netural gear so I can make the dump go up and down without the truck moving but I can make it go up with it in gear too. so we figured who needs third gear anyway. .
so take that third gear out.
now on to the fun, the shaft inside the tranny is splined so I couldn't just stick a longer rod in there to get the longer output I wanted so because I need the splines, this is what we did.
we cut the top shaft in half then we will flip the long side around , reattach the shafts with a custom made cupler so second gear lines back up, and now we have a second output out the back.
so I know you are all thinking that the shaft spins all the time so how to you stop the box from going up and down all the time.
this output will power the shaft to the screw drive but this conector shaft (pto) can be engaged and disengaged with a servo. more on that later as all the work is not done on that yet.
I know there will be a few issues and I know there might me some some cons to this setup but I wanted to try something different. and trying something different is fun, or at least that is what I try to tell my wife
thanks for looking
thanks to Steve for the nice coupler he make on his lathe
Old 02-09-2011, 02:21 AM
Weaver Of Dreams
Thumbs up Re: my first semi build (dump)
Wow Jason, very impressive. Thinking outside the box... That's the way to do it.
-Mike
Old 11-14-2011, 10:27 PM
redbullcrawler redbullcrawler is offline
redbullcrawler is on a distinguished road
stock tranny.
thanks for looking
You need to get this project back to the shop so we can have more fun making the pto
Old 02-10-2011, 12:55 AM
chaseracer's Avatar
worked on my new box sides tonight here is what I got done.
X2
