Old 02-01-2011, 08:09 PM
SmallHaul's Avatar
Default Re: Unit Cable Hoe
Originally Posted by 9W Monighan View Post
Scott, I'll get you some images from a B-E book so you can get the geometry correct. That thing is working nice. Looks like the bucket will have to be cured more seeing the dirt falling out too soon. I have some of the small machines: 10,15,20,22,25B parts books to look at.
Steve, I think the straight angle will be fine after the teeth are on there. Do you have any good pics or documentation of the pulley tower by the cab on a 22B Hoe? That is the part I can't figure out how that is set up. It is just a single loop of steel with pulleys on top so, the cable setup must keep the tower in position?
Scott
"No load is too Small"
Old 02-01-2011, 08:12 PM
SmallHaul's Avatar
Here it is loading the Mack with the new pulley setup. It lifts the load much better with the pulleys setup like the 1:1 unit.
http://www.youtube.com/watch?v=syd2XaANbuU
Scott
Old 02-01-2011, 11:28 PM
Jared Jared is offline
That's called the jack boom. The boom hoist holds it from flopping forward and the weight of the boom/stick keeps it from flopping backward. The boom hoist has about a four-part line. Then when you're digging deeper you lean it forward a little and when you're digging shallower you lean it back a little as needed. i think there are usually three or four sheaves on it. Two on the outside for the boom hoist and one in the middle between the uprights if using a two part line to the top of the stick or two in the middle if using a three-part line. I would recommend finding an old copy of "Moving the Earth". Among other things, there are good explanations of revolving shovels and the various attachments.
http://cgi.ebay.com/MOVING-EARTH-WOR...item5adc732dc6
This is close to the one my dad has, which I think is a '60's vintage. I don't know if the later editions have as much cable machine stuff. It ain't cheap but it's worth it! Every kind of earthmoving machine is covered.
Looking good!. I know this is more of a proof-of-concept thing so maybe you've already considered this, but splitting the end of the stick into a "Y" and attaching each leg of the Y to the bucket would help the bucket fill rather than dirt piling up against the end of the stick.
Old 02-02-2011, 12:21 AM
Here's a reeving diagram that's not very good. It may raise more questions than it answers.
http://www.tpub.com/content/construc...201-120049.htm
http://www.tpub.com/content/construc...201-120050.htm
Actually the picture of the 1:1 in the very first post isn't too bad for showing how it's done- if you know what you're looking at
Old 02-02-2011, 06:14 PM
Finster's Avatar
Finster Finster is offline
Finster is on a distinguished road
After watching the video I think you test of the boom was a big success. I think it works great! Well done! Since people are sending you BE info I thought that this video might help as well.
http://www.youtube.com/watch?v=1rlBuDefgog
Brian
Finster shavin' and smokin' a cigar?!?!
Old 02-02-2011, 06:44 PM
SmallHaul's Avatar
Thanks Finster, that is a good video of an old Hoe.
Here is a quick video of the Jack Boom moving:
http://www.youtube.com/watch?v=ZHwxtKFnJD8
And loading a truck on flat ground:
http://www.youtube.com/watch?v=Ovh1vyhqPBk
Scott
