Construction Equipment Tech Hydraulics, Electronics, General Engineering, ect in constr equip |
Not sure about your radio sir....but with a spektrum dx7 since there is built in fail safe with each model i just park the one - make sure it's in neutral or soemthing then switch over the radio and then drive off with the second....Pretty neat actually.....
Yep, I think Spektrum call it model match, or something like that... its a really neat idea and something I want, however, spektrum patented it... I am am reluctant to buy another radio, plus I might need 10 proportional channels soon..
Elliot. |
14mz thats a nice radio, in theory you could have both models switched on and just switch between model memorys, im not to familiar with the 14mz whether you have to turn it off and back on again. You would need to test it though, ive done it once with a plane where i turned the radio on and the plane then realised it was the wrong model so just switched the memory and everything worked but half way through the flight i lost control, obviously its not so important with ground based stuff but you dont want your track loader to go ape**** into a bridge or something you just put it on the construction site
![]() Im going to pull another reciever out of 1 of my helis tonight so ill have a play about and see if it works ok. |
That's what I was hoping for, but have been told that every rx that is bound to the radio and powered up will effectively be listening for radio inputs, regardless of what model memory I have selected on the radio.. although I think you can cheat it, buy changing the radio settings from FASST to normal, but I need to do a little reading on that. However, you are 100% correct for a spektrum radio setup, they have a feature called model memory, so only the rx you bound in that model memory will function. However, I have been surfy today and found this... seems like the exact device I need. http://translate.google.co.uk/translate?hl=en&sl=de&u=http://www.flymotec.de/product_info.php/info/p46_modell-wahlschalter.html&ei=NA9cTcnqAdGHhQeGk9ntDw&sa=X&o i=translate&ct=result&resnum=1&ved=0CCMQ7gEwAA&pre v=/search%3Fq%3Dcti%2Bmodell%2Bwahlschalter%26hl%3Den %26client%3Dfirefox-a%26hs%3DP46%26rls%3Dorg.mozilla:en-US ![]()
Elliot. |
that would work but you would have 1 fm reciever and 1 2.4gig and switch between the 2, ill go put 2 fasst recievers on now and see if they both work
