Old 02-28-2011, 02:25 PM
D8R D8R is offline
Default Re: D8R +463 in 1/5,6
Thanks for the comments, those encourange words make me try harder!
Tony, the servo-valves has not been tested yet, but Roland (builder of 988 loader) has used same series valves (german HAWE) and had no problem with normal capacity servos. The valves are balanced so servo has no more than internal friction to fight against.
Did get the anti skid plates today They turned out just as good as aspected. The big plate outside cab will be cut to fit and bended when new cab is in place. This part has 501 holes, incl some 1,6mm mounting holes for round head Torx screws.
Did the safety railings on cab from 5mm copper tubing, they will be brazed to the new cab.
When trying bend multiparts to same dimension I figured out using one of my old wises, drilled and taped for some screws. Then it´s to get right distance with moving part of wise, and you can do multiples!
Did found a piece 55mm tubing to track frame finaly too, so I´m very satisfied today.
Dan
Tags
1/5.6, big scale, cat, d8r, dozer
