Old 03-02-2011, 02:20 PM
Default Re: Bell 50 ton Dumper - ADT
With e.
I see on the packaging of my track,swing motors for the vario hoe with a voltage range up to 15v too... so I wondered if these motors were designed for 4s lipo in mind?
Got a link to Lifepo? Sounds interesting.
Cheers, Joe
Old 03-02-2011, 03:08 PM
with an e it is!
Yeah, my motors label also states they will run between 4.5volts and 15volts. The biggest problem is finding a speed control that will handle the higher voltages.
I'm used to RC car stuff, running 2S or 3S type batteries. I think 4S Lipo would be a little too high as a charged lipo is over 4.2volts per cell.
But these 4S Lifepo cells http://www.hobbyking.com/hobbyking/s...dProduct=14067 seem like a good replacement for the 12volt nicads/nimh. From what I have read they are the A123 cells that were used in the dewalt power tool range, they are stable and less prone to bursting into flames.
I need to do a lot more reading, but they also appear to have a 2000+ life cycle? However, you'd need to buy new chargers
Elliot.
Old 03-04-2011, 06:06 AM
With e.
Cheers, Joe
Hi Joe, I spoke with Frank and confirmed what batteries he recommended, the reply was either 3S lipo or 10cell Nimh.
E.
Elliot.
