Old 03-02-2011, 11:26 PM
tracksntreadslou's Avatar
Default Re: Bell 50 ton Dumper - ADT
Im very leary of using lipos..there was a fella on the garden that lost a.truck while charging..bummer..Anyway Elliot congrats ...looks like a very well built machine...I see a few hoses and fittings..Did you get the pump with your order?..Is it the same one thats used with the excavators?..thanks for sharing the great photos ...Cheers lou
Old 03-04-2011, 06:16 AM
Hi Lou, its very strong and I am very happy with the way the parts fit together.. and quickly as well, it engineered to take a lot of weight.
Ref the hydraulics, there are two options I believe, one with hydraulics one without. I went for the one with. It comes with everything, pipe, fittings etc. I assembled the pump last night... photos will be online tonight.
Not sure if the pump is the same, I will ask Frank when I next speak to him.
Elliot
Elliot.
Old 03-04-2011, 10:41 AM
Looks great Elliot.
What color are you planning to paint it ?
Keep the pictures coming
Old 03-06-2011, 05:07 PM
Thank Ari, although its put the tipper build on hold for the moment :-)
Still not sure on the colour, was going for the Bell yellow, but after seeing the white ones... not so sure.???
Elliot.
Old 03-06-2011, 05:08 PM
Little bit of an update....
Well, after three evenings work, to cutout, file, sand, grind and glue the cab together… doesn’t look a lot of work from the three photos, but it took about 10 hours in total and was my least favorite job to date …
Elliot.
