Old 03-06-2011, 12:35 AM
Default Re: Mack M75SX
Hey Lynn, I've had good luck with this program opening .dwg files. Case in point you have to have it for the Western Star body builder download's (zipped).
Yer welcome, Neil#2 aka doodlebug
Old 03-06-2011, 01:36 PM
tracksntreadslou's Avatar
Coming along very nicely ..Im pretty amazed at how fast you build these things steve..and with all the other work you have lined up its good see your making time to do your own stuff.
Hey steve what are your plans for diffs for this brute?..Looking threw my spare parts box i came accross some tamiya Mammoth/juggernaut diffs that look very hefty..they are top drive and with a little mods i think you could make one with a rear output as well..
Old 03-06-2011, 04:28 PM
Lou , I'm actually going to make my own drives using HPI savage internals . I got the spools and pinions and I just ordered my bearings . I got to the point ( finally ) to work on others parts to a certain time then I work on my stuff . I just need another lathe now I spend a lot of time resetting or I put my lathe work on hold till I get a break between set ups .
Old 03-06-2011, 04:36 PM
Get more chucks for the lathe and a Aloris toolpost. Then you can switch out a chuck without disturbing a setup and leave a special tool in a holder.
Old 03-06-2011, 05:49 PM
kerst's Avatar
kerst kerst is offline
Sounds very interesting!
Got some pictures of the parts?
Kerst
Old 03-06-2011, 08:27 PM
Kerst
Kerst , I'm Making mostly Wheels right now and air cleaners and fuel tanks . I have pics in IHB in the vender section .
Steve , I have a tool post not the aloris brand I begged for that a long time ago when I was in my dads shop . as for chucks I would have a bunch but , I can't get the right thread for the adapter plate . I need to get 1 made for my 3 jaw
I was just ready to make my back hangers for the front springs , I need another .25 " end mill I don't think I'm getting HSS any more Well I did get some more done front springs and center webbing for the rear . I'm hopping to start on axle housing this coming wknd ,wife has plans on sat
OH Scott , I put the trans in last night I put the gears I had from travis' ( bigger bull gear and smaller pinions ) motors run great
IHSteve
Old 03-10-2011, 10:24 PM
No I did not stop I got some nice end mills yesterday and spent last night and tonight making the front axle and rear spring hangers for the front .
I also got some aluminum flux for welding aluminum with the torch and it works real well . So looks like I'll be making the cab in aluminum works just like brazing
I hope you can see these
spring hanger
the axle
thanks for looking
Steve
Old 03-11-2011, 07:22 AM
Tamiya Cowboy's Avatar
WOW Steve this thing is going to be a monster..keep up the great work..
Paul W. "Tamiya Cowboy"
Old 03-11-2011, 08:24 AM
SmallHaul's Avatar
IHSteve
That trans should motivate it well. That is one beefy machine!
Scott
"No load is too Small"
Old 03-11-2011, 10:19 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Boy you learn fast! Great looking work! I stopped getting HS tooling quite awhile ago. Carbide is more expensive but lasts much longer, so it's a fair trade off. My shop time has dropped to about 0 after knee surgery. And to top it all off, I think my Sherline mill is in need of new gibs. Really not bad after 20+ years of use and a new bed.
Lynn
Old 03-11-2011, 11:43 AM
Papy Papy is offline
Talking Re: Mack M75SX
.....the axle
thanks for looking
Steve
OK, you will say I'm a "rivets counter", but the M75 had a tubular front axle ! So I propose you to send this one to me (will fit perfectly for the LRVSW) and make a new one with the correct design
Old 03-11-2011, 12:00 PM
I know ,Papy I sometimes throw my own twist to things the body is off a lil to I think I got the rear taper to long . I was going to do the tubular axle but I just felt like milling an I beam front . I may do another but as a tractor but thats a lil while yet . I think I got enough going for now
IHSteve
Old 03-21-2011, 10:54 PM
With hubs drying waiting to be put together to finnish this order finally I stole some time on the lathe and turned out 1 rear housing
and dabbled a little bit here and there on some of the cab
thanks for looking
IHSteve
Old 03-22-2011, 01:33 AM
Looking Really good steve..Making good progress..Those diffs are looking like they will be bullit proof.
Old 03-22-2011, 09:10 AM
td9clyde td9clyde is offline
Dozer Builder
nice work that mack is gonna be huge when it is all done
Old 03-22-2011, 10:51 AM
kerst's Avatar
I like the way you made the axles! very nice work!
Kerst
Old 03-22-2011, 12:01 PM
steamer's Avatar
steamer steamer is offline
Steve. Great gob on the axle. How do you plan to hold the joint together, setscrews or bolts. She's going to be heavy duty, that's for sure
Rob
Old 03-22-2011, 12:17 PM
Kerst
Rob
thanks guys
Rob , I'll be using 3mm bolts which I still have to mill bolt areas on the flang once they're bolted together then chuck them back up perpendicular and bore for the pinions that'll be a fun setup
Steve
Old 03-22-2011, 12:22 PM
Awesome work, Steve. I am looking forward to seeing the updates, as they come, which is usually what I reply to all of your posts! You have a lot great project builds going at once. I can't believe you get as much done as you do. If I even tried to do what you do, it would take me a lifetime, probably.
Old 03-22-2011, 12:39 PM
I don't know Nate , the new/old cnc mill has me occupied right now to get it going . Oh thank you
