Old 03-08-2011, 04:49 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Default Re: Is this a good machine for the $$$
Not a bad starter mill. Only thing that is wierd is the .062" per revolution on the X and Y handles. Looks about like the one that quite a few of us have only different color paint. Wish mine had the R8 spindle and not an M3. I have never been satisfied with mine but I think it is my fault and not the machine. Just need to take the time to completely take the table off and clean everything.
Lynn
Old 03-08-2011, 06:35 PM
Brian in PA's Avatar
I'd rather be truckin'
Thanks Lynn. I want to get one to play with but don't want to put out a ton of coin! I haven't used a mill since high school shop class, in 1993 ! I figure I could learn how to run it.
Thanks!
Brian
Old 03-08-2011, 07:24 PM
Vanisle Vanisle is offline
Vanisle is on a distinguished road
If you spend a little more you can get a bigger Bf sized mill from Grizzly. The table is much larger and it is a lot heavier than the LMS mill.
http://www.grizzly.com/products/Dril...th-Stand/G0704
The only problem is they are so popular they are often sold out. You can see more about it here:
http://www.cnczone.com/forums/bencht...zly_g0704.html
and here:
http://www.g0704.com/
