I deiced to over haul my 6x6 rock crawler and go with something more scale. I try ed to have it done for Indy this year but the black truck was being to much of a pain in my rear. So while I was waiting for my supply's for the fire truck build I deiced to get it back out of the closet and get going with it.
SO here it is I am going off the KW 963 family of trucks. Witch there is many different ways you can order one of these monsters this is the one I liked most. ![]() ![]() ![]() ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 08:51 PM. |
I started with a new frame 26 inches long with FH12 frame rail tips.
![]() Next to shorten the sleeper by a 1 1/4 ![]() ![]()
Then I cut the fenders off and angled the nose down and I lowered the sleeper to match the roof of the cab.
![]() ![]() Now to start filling the hood back in. ![]() [/b]
Now to build the fenders, I built them out of 1/8 to make them good and strong.
![]() Now I had to modd some stock KH air cleaners to match the ones on the real truck. ![]() ![]() ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 08:55 PM. |
![]() ![]() ![]() Air cleaner on the fender. ![]()
Now I built the tire rack for the back of the cab and I got building and did not take picks but here are some afters. All alum sheet and angle taped and screwed together with a chain rack on the passenger side.
![]() ![]() Now to build the drum winch. I am not going to make the winch itself work but it will work. :-/ Heres the parts we need.. ![]() ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 08:56 PM. |
Ok here is how I am making the winch work. i am mounting one of the good scale German winches. the winch that started all the other winches nice thing about these is they will pull ALOT of weight with out breaking.
![]() ![]() Then I mounted a fair led in the top of the deck for the cable to come threw and wrapped the cable around the drum. So when you run the winch teh drum will turn . ![]() ![]() [/B]
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 08:57 PM. |
Now i still have alot of detail to go plus the trailer still needs to be built.
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 11:09 PM. |
I got a little more detail work done late last night on the rig. I made a movable 5th wheel and 5th wheel ramps.
![]() ![]() And as you can see in the picks above I also added a RC4WD King Kong hook. Then I added a edge for the chain box out of brass angle. ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 11:11 PM. |
Then I made square blinkers out of 3/8 square tube and cut the King hauler amber light to fit. And I also added brush guards out of brass over the blinkers.
![]() I got the tranny mounted. I used some milled shock mounts for the F350 they were the perfect size and hole pattern. ![]() I also got 2 of the 3 drive shafts in my other one did not show yet. ![]() Then I got the steering done. I used bigger alum tie rods and emaxx ball joints and I added alum black drive hubs and junked the plastic ones. I also used a 645 for the steering and a 5626 for the shifting. ![]()
Then i thought a set of these were fitting since it would be 11.4 Lipo and a 55 turn with a 8 tooth.
![]() And the rig is getting a full set of custom milled hubs ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-04-2011 at 11:12 PM. |
I got a little time this weekend to start on the trailer of the Oil Field Rig. Stock tamiya flat bed trailer with F350 leafs and CR01 wheels and tires I have added a rub rail and the roller on the nose of the trailer I still have the rear plate and roller left to do and leg and lights.
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-05-2011 at 03:35 PM. |
Well I got a great little package in the mail today. Lynn made me some new hubs for the beast and I must say WOW
![]() ![]() How they look in the wheel. ![]() ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-05-2011 at 03:36 PM. |
Full View
![]() They really finish off the look of the wheel I am very happy with them and the quality of them is 2nd to no other.. Greg wanted some side by sides so here you go Greg keep in mind the body will be about 1/4 high when mounted. ![]() ![]()
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-05-2011 at 03:37 PM. |
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-05-2011 at 03:38 PM. |
I got the back plate made on the trailer last night it came out perfect I just have to do some finish work to it to clean it up and mount a brace on the back side for when I am winching loads up.
Here are some picks of how they winch onto the trailer..the trailer lay's down on the ground perfectly just like it should.
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-05-2011 at 03:39 PM. |
And a few other picks..
I got a little paint and decals on the Oil Rig trailer a week ago just did not have time to get picks up so here they are..
Paul W. "Tamiya Cowboy" HI.. My name is Paul.. And.. I.. Have a Cabover Addiction. RIP FreddyGearDrive 2-12-59/12-19-11 "LET IT EAT" Like Us on Facebook "Corn Field Mafia" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Tamiya Cowboy; 02-06-2011 at 06:10 PM. |
