Old 03-26-2011, 08:09 AM
FreddyGearDrive's Avatar
Default Re: Hyd Pump - What did I just buy?
What are they made to do? Pump fuel for jets? Do you know what the max pressure is? Most of all,can you run them for longer than 2 min,before there red hot? If there made for airplane landing gear,be careful you don't burn your hand on it,if you run for any period of time.
For $35 you can't go wrong,even if you have to mod them for your use.
FGD
Old 03-26-2011, 09:03 AM
just did some checking on it . It is used in the health and science ind.
Specs : 3.2 L/min (0.85 GPM), 5.6 bar (80 psi), 0.316 to 1.12 ml/rev
no motor included . original motor is magnetic propulsion , with some work a elc motor could be configured to run it . They are made to handle some volatile stuff . the interesting thing is , My wife could prob. get them from work the pressure is no concern for me as the flow is ,although it appears to have some sort of pressure regulating apparatus on it . well we shall see
