Old 04-01-2011, 02:02 PM
D8R D8R is offline
Default Re: D8R +463 in 1/5,6
The radio is a Multiplex Royal Pro 9 channels (7-9-12 available) and is a 2,4 Ghz with full telemetry. There´s possibility to store individual settings for 20 different models.
My set up for the D8R is:
Channel/description
1/ speed forward-reverse, left stick
2/ steering left-right, left stick
3/ blade up-down, right stick
4/ blade tilt left-right, right stick
5/ ripper up-down, right stick
6/ ripper tilt backwards-forwards, right stick
7/ 2way switch between 3/4 and 5/6 on right stick
8/ lights on-off-wipers on
9/ engine speed stepless
The telemetry will show following info in window on transmitter
-voltage on battery for reciever and lightning
-temperature on engine
-temperature on hydraulic oil
-revs on engine
All telemetry can be programmed with warning levels, audio or/and visable in window.
The programming was not easy, but got good help from selling dealer and from factory support.
Did think a 7 channel was enough but was convinced that I should go an extra 2 by seller, thanks Per!
Lessen learn, could have had use for more! if you have to choose go for as many as possible, you may need it for next model
Will try some 2-C paint during weekend, another new experience.
Dan
Tags
1/5.6, big scale, cat, d8r, dozer
