Old 04-14-2011, 06:04 PM
Car5858's Avatar
Car5858 Car5858 is offline
Default Re: chassis question
On mine I do that for a scale look. Sets the correct cab height, and wheel clearance, or to set the trans in the proper position.
Old 04-15-2011, 12:23 PM
scalelover's Avatar
Originally Posted by DieselKid View Post
Are you seeing this double frame setup on dump truck builds?
Reason I ask is because I know I've seen a few guys on here run such a setup on their dump trucks.....they're basically using the top set of rails as the frame for their dump box and give extra clearance between the top of the tires and the bottom of the box. Or to hide extra electronics, battery, etc.
Hopefully others will chime in as well,
-Alex
Ive seen it on all types of builds from dumps to just standard cab setups, the dump setup I had figured was for clearance and mounting of hydros etc etc but the others are what I was unsure on.
--Dan
Thanks for the input I had figured that the scale appearace was one reason I had not even thought about the trans mount heighth. I have seen quite a few this way especially when they are 6x6 I assume to bring cab height up to clear the axle and such??
Thanks again for your input guys any more is greatly appreciated as well
--Dan
