Old 03-27-2011, 07:08 PM
Default Re: Mack M75SX
Hope everything lines up ok in there Steve. That's definitely a strong setup if the pinion holds up. Do you have a link to the gears you are using?
Old 03-27-2011, 07:27 PM
Steve , here's the pinion http://store.rc4wd.com/HPI-Racing-Be...1-_p_1377.html
the rest I got off ebay same as what I have in the pan only I made the axle housing for the truck . Here's a listing http://cgi.ebay.com/HPI-Savage-X-25-...item2eb3d51c69 Oh yes everything lines up thank gawd I didn't want to do it all over I still have to make the axle shafts . I may take the cups off the diffs and run the axle shaft right in . This what the cups look like http://cgi.ebay.com/HPI-86864-Differ...#ht_4874wt_872 they go into the spool and you slide a pin through the end then the bevel gear goes over top .
mike , your looking at the rear axle components . axle housing done on the lathe
thanks Clyde
Old 03-27-2011, 07:38 PM
td9clyde td9clyde is offline
Dozer Builder
i really need to get a four jaw chuck ........but then again i gotta get my barn made into a shop first hope to be gettin it all done this summer
Old 03-27-2011, 08:43 PM
Heavy Metal Heavy Metal is offline
Heavy Metal is on a distinguished road
Beautiful Steve.
Old 03-28-2011, 11:25 PM
Jared Jared is offline
Looks good! I've been following along partly because I don't know much about Mack off-highway trucks and because it's so different.
I was curious how the tandem axles would be driven. Not trying to be nit-picky, but is this the way the axles will be oriented when they go in the truck? If I'm looking at them the way I think I am they may wind up with one spinning forward and the other backwards unless one is flipped upside down. The front axle ring gear will reverse the rotation of the jackshaft. You may already have that taken into account but I would hate to see it happen. Years ago, a couple guys from my area built a monster truck from surplus army truck parts and when they were ready to take it for a drive the axles turned opposite! I'm not sure if they ever got it driveable.
Originally Posted by ihbuilder View Post
Old 03-29-2011, 07:16 AM
Thanks Guys
Jared , yes , when put together the rear rear will be flipped . I guess I could have went into more detail and made a power divider like the real trucks .
IHSteve
Old 03-29-2011, 08:21 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Thumbs up Re: Mack M75SX
WOW!!! your workmanship just seems to be never ending. Can't wait to see it under power.
LYNN
Old 03-29-2011, 09:38 AM
rc_farmer's Avatar
Master Builder
Steve, you gonna have to give a shop class one day with all this great stuff you come up with....what's that thing they say about neccessity being a "mother"
keep up the good work!
Giving up is not an option!!!
Rob
Old 03-30-2011, 10:39 PM
I can't wait to either , Lynn I'm tired of man handling coal
Rob , I do not think you want to take my shop class OSHA would prohibit it plus you'll have to wash your ears afterwards a lot of this is the main music in the shop some days , ###&&($%@!)##%%@
OH , " neccessity is the mother of invention " is on my shop door
just looked at another lathe today I wasn't going to but curiosity never really killed the cat , the handle fit perfectly now the fun part trying to get it
Old 04-04-2011, 09:46 PM
I did a little yesterday mounted the front axle made some hinges for the body may mill an authentic looking assembly and I've been dragging my feet on making the rear hangers in hopes of using the big mill but got tiered of waiting
thats the back side of the hanger still got hrs to go on just that 1 will the tiag hold up
Old 04-16-2011, 10:32 PM
An excavating job came up All t&m and the customer keeps adding on so I'm not getting much time in the shop but did manage to glue some styrene together in the evening after getting home @ 6:30 as the alum was not welding well ( to much warping ) but this came out well
IHSteve
Old 04-16-2011, 10:39 PM
Stylin n profilin's Avatar
Stylin n profilin Stylin n profilin is offline
I'm tryin Boss!
Stylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura aboutStylin n profilin has a spectacular aura about
SAAAAAWWWEEETTT there Stevie boy....Thats some nice styrene work boss
One Bus Stop Short Of The Short Bus...
Old 04-16-2011, 11:23 PM
RAIDERS RAIDERS is offline
Super Moderator
RAIDERS is on a distinguished road
looks great steve...
LARRY,the doggy dish dealer
Old 04-16-2011, 11:33 PM
steamer's Avatar
steamer steamer is offline
Steve That styrene is great stuff. Only thing you have to watch out for when your going for a cool one is witch bottle you grab!!! Nice Work.
Rob
Old 04-16-2011, 11:47 PM
Rob
OH OH thats why it's empty
thanks guys
Old 04-17-2011, 12:11 AM
tc1cat's Avatar
Super Moderator
Looking good there, Steve. You'll have it finished in no time
LYNN
Old 04-17-2011, 09:12 AM
Snochaser's Avatar
Looks great Steve! I hadn't seen what you plan on using for the dumping mechanism. What do you have up your sleeve for that? I'm sure it'll be slick as snot.
Ben
Old 04-17-2011, 10:20 AM
stock hydros 2 - 4 stage cylinders . I still got a lot of shop time on this
Old 04-17-2011, 11:05 AM
SmallHaul's Avatar
Shaping up nice Steve!
Scott
"No load is too Small"
Old 04-17-2011, 12:37 PM
Dozer Builder
looking great i am likein that truck
