#401
Sorry to hear that your system went down.
![]() Autocad 2000 full version dosen't require a key code and can be loaded onto any xp or win 7 64bit computer. You just have to make sure that your Win 7 installation can run 64 and 32 bit programs. I will try to locate you a copy of the Acad 2000 version if you want. Carl |
#402
I tried the 2000LT but it wouldn't load because of the 32bit vs 64bit. I don't know how to operate Autocad very well but now I'm forced to learn. I downloaded a demo of 2012LT and It is working slow but I guess that's because it's running through the internet. It's really hard for me to learn how to do any new things these days. I guess my brain is working without enough Ram ![]() |
#403
Thank's for posting the Lakeside open house. I met Larry last month in Vegas,
"He's a wonderful guy to know"! Met him at the HCEA Both. Later, Neil#2 aka doodlebug. |
#404
Confusion is my default setting
![]() I stopped by the post office this morning, you should have it by Wednesday. ![]() |
#405
Well I managed to get some done this weekend on some of the suspension rope sheaves. I still need to make some brackets that'll get attached to the boom chords that will hold the small shackles I made up.
Steps for making a shackle: Turn a 3/8'' sq. ![]() Mill inside flat ![]() ![]() Bend ![]() Mill ends round ![]() Finished parts ![]() ![]() |
#406
No detail left untouched
![]() You are without a doubt one of the best craftsmen I've seen work with metal. Jordy |
#407
Truly amazing work Steve!!
![]() ![]() Brian |
#408
Nice work Steve. That is amazing that you could make that piece out of a solid piece of 3/8 stock and bend it centered so that the ends line up! Very nice looking parts too!
#409
Now that is just showing off
![]() ![]() ![]() Steve, are you going to try and make the NAMES show in Detroit this weekend????
LYNN |
#410
Nice demo on making the shackles Steve.
#411
I do alot of metal bending in my regular job. I could have made them a little nicer if I took the time to make a better jig rather than using a flat bar with a 1/8'' drill bit to get the radius started and then press them into a die Funny thing, when I got to the bottom of the pile of sheaves I discovered 3 that had a smaller bore. These were supposed to be used on the three shackles. I made the OD to match the larger bores
![]() ![]() I hate stopping on something and forgetting what I was doing a month prior ![]() |
#412
I forget where I am on a project also at times. Lately I have started writing myself reminder notes.
#413
wow, had never been able to duplicate that work, Steve.
Still hope to see that machine in real. Nice drawings to! Dan |
#414
Finally I got the safety rope brackets made and fastened to the boom. I hope to raise the boom this week with the new $180 worth of wire rope I bought.
![]() ![]() ![]() Those Lego tires seem to be the correct scale so I'll wire them on the top. ![]() |
#415
Nice progress Steve
#416
http://www.harborfreight.com/catalog...q=soda+blaster
Hey Steve does this help answer the previous question on soda blasting? Later, Neil#2 aka doodlebug. |
#417
#418
Wow Steve, the shackles and sheaves are amazing. The boom is huge and very realistic looking. Nice work as usual. Ready to see it working, in person, that is.
Joe |
#419
Here is another big milestone in this build! I took the time this evening to reeve all the wire ropes that hold the boom. I need to design some miniature Crosby Clamps instead of using the copper sleeves. I need to make a tool to smash them better than the wire terminal pliers I'm using. ![]() Next step is to get the boom hoist winch installed and see if it has enough power to lift the boom off the ground. While pulling it up with my hand it was easy after it was up about 10deg. ![]() ![]() ![]() ![]() ![]() ![]() |
#420
simply in awwww just amaizing the detail still blows my mind on this crane
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
