Go Back   RC Truck and Construction > RC Truck's Defenders of the land. > Tanks!
Tanks! If is has Tracks it goes here..
Old 04-27-2011, 09:32 AM
Car5858's Avatar
Car5858 Car5858 is offline
Car5858 will become famous soon enoughCar5858 will become famous soon enough
Default Re: Tamiya M26 Pershing
I see that you have the IR battle unit in it.
Old 04-27-2011, 01:55 PM
Brel's Avatar
Brel Brel is offline
yes it is IR battle ready, all of my Tamiya tanks and the Heng long tiger 1 are battle ready
I go to meets when I can and it is great fun trying to recreate WWII battles in 1/16th scale
I am giving the tank its annual pre season service at the moment and have ordered some replacement road wheels because the plastic housing the bearings has split on a few of them, I have checkd the final drives and they are clean and free of debris and not worn at all
Old 04-27-2011, 02:37 PM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
You might want to check your bearings in the roadwheels for plastic compatible grease! Had a lot of guys buying cheap bearings from China that had the wrong type of grease in them which caused bunches of problems until they replaced the bearings or completely degreased the bearings and put in plastic compatible grease. Pershing is a great tank to battle with.
LYNN
Old 04-27-2011, 04:18 PM
Brel's Avatar
here is a picture showing one of the cracked wheels along side a good one
when I get the new wheels I am going to fill the gap around the bearing housing with epoxy resin to make them stronger, why did tamiya make them this way when they would have been better making them as one solid disc without the gap in them
Old 04-27-2011, 05:45 PM
Car5858's Avatar
That was the engineers trying to save on materials cost
If you can find a bras tube the correct size, cut small rings to fit over them.
The other option would be to cast new wheels from aluminite.
Old 04-28-2011, 02:02 AM
Panther F's Avatar
Panther F Panther F is offline
Panther F is on a distinguished road
I've used plastic compatible grease in ALL my bearings for my Pershing (and all other tanks) since 2006 and have experienced no problems at all, even after a few IR battle too so the resin might be an overkill. A messy one at that.
BTW, nice looking Pershing too!
- Jeff
Old 04-28-2011, 08:50 AM
tc1cat's Avatar
Super Moderator
From your pic, I would say you have bearings with the wrong type of grease. Yours look exactly like what I saw happening with the wrong grease. Lack of a solid roadwheel is exactly what Car5858 said. Engineers trying to save money.
LYNN
