Old 04-28-2011, 10:27 PM
Default Re: Hydraulic Pump Motor Control Options
I would guess that like most things in life, there are always exceptions. Since the hydraulic pumps are coupled to the engine, it's not uncommon for the pump RPM to vary all the time too. Look at a wheel loader, for example. Lots of driving forward and backing up. In between, steering when the engine is winding down, or at idle, and lifting or dumping the bucket. Pump (oil flow) output varies quite a bit. Now something like a back-hoe or an excavator is a totally different story. Maybe even a skid-steer, but the demand for hydraulic flow on a machine that is constantly moving, and uses hydraulic motors for the drivetrain also, actually needs good flow, and maximium pump output. Then we also could consider the variable displacement hydraulic pumps, that put out more flow, when it is demanded, regardless of engine RPM.
So I would think on a small scale model there is no reason why the pump can't be throttled back to reduce heat, and increase battery life. Sounds like a win win situation to me. Heat is the worst enemy for a hydraulic system, next to oil contamination. Yes, you could put a heat exchanger on any hydraulic system, but on a scale model, it would be easier and cheaper to throttle back the pump, or shut it off completely.
Out in industry, where I work, we are starting to see some hydraulic pumps run with electric motors, and variable frequency motor drives, which throttle the motor and pump RPM back, when the flow is not needed. The worst is when an operator walks away from a machine and leaves it running. The oil is constantly going over the relief valve and the motor is drawing more power in doing so, while also heating up the oil for the next few hours. Yes, the heat exchangers cool the oil too, but it is still getting warmer then it normally would, if the machine is cycling.
Thanks for the explanation. Yes I did take offence!
I work for the CAT Rental Store and work on all kinds of hyd systems by a lot of different manufactures JLG, Broderson, LULL, Bell, Trail King, and the list goes on but hay my boss will be glad you explained to me how it works.
All I am saying is why over complicate some thing you can take care of with a cheap switch or cooler.
Originally Posted by egronvold View Post
You can get a suitable ESC for $8 But you do need a radio with at least 2 free mixes.
$8 esc shipped from where and will last how long and who warranties it.
Old 04-29-2011, 01:34 AM
Travis, I know you work for a Cat Rental Store. Relax. I'm not out to bust your chops. If that's what you think the purpose of my post was, I apologize. I was just making a point that pump speeds and outputs vary all the time, so why not do it with a model too. Given the choice, I'd throttle back the pump, AND have a heat exchanger, but if you only do one, I'd throttle back or turn off the pump altogether. Reduce the current draw, and save wear on the components. That's just my opinion. Everybody has one. You don't have to accept or like them, nor take offense to them. I'm just saying....
Old 04-29-2011, 02:30 AM
Sold at hobbyking; Turnigy 30A (not including shipping). It's quite small, which is good since space is often limited. I think a ESC is a good option in loaders and ATDs, but in an excavator you might as well go for an on/off switch.
My two main reasons for using ESC/ switch are not to have to listen to the awful sound of the hydpump when full flow is not necessary and to avoid unnecessary draw of current.
Many may think there's a delay in the hydraulic functions when using ESC/ switch, but there really is not. You can save a lot of AMPs just learning to operate machines with hydraulic steering by just driving "smart" --> less battery changes = more fun
It would also be cool to change the counterweight on the trackloader to a heatsink with a fan. That would be almost as "the real ting" I guess.
Old 04-29-2011, 08:08 PM
Izzy and I talked about it and it would be cool but I felt it was a bit unnecessary for a toy. Right now with my loader set up it will run for 45-60 min on a battery and that is fine with me. As for the esc yes it has a good purpose but I like to keep things simple and it also give newcomers a simpler way to do things till they get to know their equipment and radios.
Old 04-30-2011, 10:13 AM
Juganought Juganought is offline
Juganought is on a distinguished road
When there is not a lot new, I tend to read these posts. You guys have too much talent but I draw the line here....Izzy and I talked about it and it would be cool but I felt it was a bit unnecessary for a toy. Toy!!!! how dare you Travis No toys in my house.. except baby boys stuff.
Dont mess with ma trucks
