Go Back   RC Truck and Construction > R/C Truck's Manufacturers/Venders/Retailers > TC Customs
TC Customs Parts & accessories for your semi builds.
Old 05-04-2011, 08:59 AM
tc1cat's Avatar
tc1cat tc1cat is offline
Super Moderator
Talking Light unit directions!!
For all of you kind people who have ordered the 5mm lens units, here is what is needed to install the units:
1) You will need either an "N" drill bit or a 7.70mm drill bit. You can use a slightly bigger drill but not much as the rim around the body is only .040" bigger that the body- .020" per side!!
2) Hole must be a minimum of .250" deep. I imagine most will just drill thru as you need to run the wires for the LEDs.
3) Most of the lenses are a tight fit in the bezels. You will want to cement them in once you have the bezels installed. You should be able to remove the lenses from the bezels with a gentle push but some may fit tighter that others due to mold flash on the lenses!
I hope that everyone find the assemblies what they were looking for
I will post instructions for the 3mm units when I have finished all of the orders.
LYNN
