Military Vehicles. Trucks/Support Vehicles in here. |
Fist of all let me just say your wood models are OFF THE CHAIN!!!
And this Oshkosh is going to be one amazing ride... Just like the real thing, only smaller ![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
Thanks, to bad I never kept one of the wooden ones for myself. Maybe the next one, but the RC bug has bitten again and it may be a while.
Made the axle master patterns today. Wood sealed with thin CA, sanded and recoated 3 times.
Carl,
I have been reading thru your thread and it is awesome, this truck is on my list of trucks to build once i get two others finished. What thickness aluminum are you using for your suspension brackets. I hope when I get the M26 done to start on one of these thank you for sharing. Merritt
Member of Central Plains Mini Truckers and Certified Army Nut |
Merritt, the brackets and frame rails are 1/16" thick. Basiclly standard extruded alumnium cut to shape and finished with a file.
I am still learning about how to build them. So far so good, changed my mind about casting the axle housings(it would cost more that the truck itself). So now I am awaiting some flat stock alumnium. These axles are designed to use Tamiya's diff setup. Thanks for looking. Carl |
