You need a high alcohol content 90% or more. The highest I have found is 91% and Freddy uses 92%. The alcohol may not work on all Paints but so far it has worked well for me. I have tried the Easy Off oven cleaner twice and had no luck both times. Maybe he used a good auto paint with a lot of hardener so maybe if you sand it to break the surface the alcohol will be able to penetrate to the primer and lift the paint from underneath.
Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
10-4. That might explain it. Stuff I was using is 70%. Where might one find 90%+ locally?
