Old 05-23-2011, 09:52 PM
ihbuilder's Avatar
Default Re: IH5070 Paystar 6X6 now a log truck
thanks Joe the cam takes a back seat for now my wife does a better job , the problem is to get her to take some time to take the pics for me what RPM motor do you have ? I got a johnson @6600 rpm I'm going to try not much torq though ( I just noticed ) we'll see I'm not sure about being able to run this in ECMT meat on the 11th I got to get on a trlr frame and some other things till a new lathe comes ( well new to me )
Old 05-23-2011, 09:56 PM
Brian in PA's Avatar
I'd rather be truckin'
Lookin good Steve!
Old 05-24-2011, 05:56 PM
Heavy Metal Heavy Metal is offline
Heavy Metal is on a distinguished road
Originally Posted by ihbuilder View Post
...what RPM motor do you have ? I got a johnson @6600 rpm I'm going to try not much torq though ( I just noticed ) we'll see
Sounds like I have the same motor. I bought a Johnson 12V 6600RPM motor off ebay and also tried the 12V Johnson motor off my Leimbach pump as a test. They both performed almost identical. Labored real bad and pulled 6 or 7 amps (blew a 5A fuse almost immediately). If I remember correctly these Idex micropumps are moving about 5 times as much fluid as a Leimbach with each revolution so I think problem is too much volume. I was going to try a 4:1 gear reduction as next step.
Old 06-25-2011, 07:59 PM
ihbuilder's Avatar
Joe my pump on the shelf to for a little . it looks out of proportion to the truck so I think I'm going to try to get a micro pump from the Germans for this 1 . I have timing pulleys for 4:1 reduction as a stacked unit I plan to get together for my TD40B and the big mack if the UMS pump will not work for it
thanks Brian
I'm pretty much shelving my projects till I get some customers caught up except for somethings I'll use as a trial run on the JD mill . Like the frame pieces for the pup for this truck .
if it does these right then I'll feel comfortable running drop deck frames .
Old 08-15-2011, 10:47 PM
ihbuilder's Avatar
last set of frames till I get a bunch of wheels out of my way
BTW : these have the ryco suspension built in
I'm trying to get these few frames out of the way before I tie up the mill on the 2nd op for WHEELS
