Old 05-27-2011, 06:13 PM
td9clyde td9clyde is offline
Dozer Builder
Default Re: JD Disk
awsome job on your disc
Old 06-30-2011, 08:25 PM
Ken Orme Ken Orme is offline
Ken Orme is on a distinguished road
Default Re: JD Disk
You did a very good job on your disc. There are a lot of parts that make up that thing.
Did you make the discs from bevel washers?
Old 07-01-2011, 12:06 AM
Default Re: JD Disk
Sorry for the misinformation. They are NOT called bevel washers.
Old 07-01-2011, 02:55 PM
rc_farmer's Avatar
Master Builder
Default Re: JD Disk
FGR, those are plastic blades
hauler, anytime, just hit me up, there is a JD dealership and/or a farm every 10 miles around me, so i have plenty access to real stuff. I'm changin the diff out in the tractor, when i get'r all back together, i will post up a vid
Ken, i know what youy meant......fender washer right, but no, they are from the Ertl disk to keep it looking scale for that size....plus, id i had made them from metal washers, the servos would be strong enough to lift it w/o some gigantic servo that would look out of place on the disk. I tried to hise the servo as best as possible.
Giving up is not an option!!!
Rob
Old 09-12-2011, 09:40 AM
Default Re: JD Disk
I finally found the name of the washers.
They are called "conical washers"
