Old 08-25-2010, 01:00 AM
A32Limited's Avatar
A32Limited A32Limited is offline
A32Limited is on a distinguished road
Default Re: I hate Tamiya three speeds
Originally Posted by ihbuilder View Post
when I had this prob on my 1st knew It was not mechanical this is when I learned of end point adj and centering on the radio . now I use the 3 position switch for shifting . If you lube that trans up when you put it together It should shift like a dozer sliding side ways on ice .
ihsteve
Mine wasn't end points though, I have the linkage perfectly dialed in, I have the endpoints on my radio dialed to perfection as well, it shifted just fine, but second was completely gone...I guess it was just sticky or something.
My uncle's over too, he drives a truck for Roadway, I let him play with it, since he's dabbled a bit in RC stuff, and I dunno how, but he scrubbed the side walk with it LOL. Nothing major, scratched the bumper (I have two new ones standing by) And knocked my last remaining passenger side blinker off, luckily I was intending on getting new ones someday anyways, or making them. I just thought it was kinda funny...I'm relieved it was only the bumper that got scratched. Though I did run it into a bush myself, and damaged a couple little spots by the air vent on that side.
Old 08-25-2010, 02:53 AM
CustomRCmodels's Avatar
CustomRCmodels CustomRCmodels is offline
CustomRCmodels is on a distinguished road
I have to go here with the other guys ,
Tamiya 3 speeds are tough !
By all the crazy stuff I have done with mine over the years , I never had a busted one or issues with it !
But I did found over time several issues with these 3 speeds not being build correctly ,
( besides the deal with linkage , servos adjustments and such )
when I acquired used Tamiya semi’s .
Bend shift forks or worn bushing inside the shift-forks are a common issue for a not properly build or “high-mileage” 3 speed.
If you want to do an extra trick , you can bevel the tooth-flanks on each gear which is used for the shifting . Then you can shift this 3 speed even under load and with full throttle ( even thought not recommended way of driving ! )
It’s all a matter of how much care you take during the building process .
A few years back , during the first Indy show , I received this nice comment from several truckers :
“ how come all your trucks are driving so smooth ? “
Take your time building stuff and during the building process check things out .
If you get a ready to run vehicle build by somebody else ,
check it out real good , if the builders reputation is questionable , rip it apart and start from scratch ( that’s what I do when I buy used stuff )
Even with new stuff , just because it’s new , it doesn’t mean it’s right .
(Wild)-Willy
CustomRCmodels
Old 08-25-2010, 05:35 PM
oldboy's Avatar
oldboy oldboy is offline
oldboy is on a distinguished road
I Have found that you can bypass the gear shift if you run MFUs'
Just lock the gearbox in which gear you want and the mfu will change speed in the different gear positions example,
in 1st on transmitter revs are low
in 2nd on transmitter revs are medium
in 3rd on transmitter revs are high
so now I am locking my gearboxes in second and lettin the mfu do the work
saves on servos and linkage adjustments also it stops the gearbox from neutralizing
so that removes the problem of lost gears
Oldboy
Old 08-25-2010, 07:25 PM
TINY-TRUCKER TINY-TRUCKER is offline
Banned
TINY-TRUCKER is on a distinguished road
I had the same probs with 1st gear would work, then 2 nd would work then 3rd would be just not there so then i just lock it in 1st or 2nd gear & leave it cause i would not be driving it to far so yer. it piss me off as well.
Old 08-28-2010, 06:17 AM
ddc333 ddc333 is offline
ddc333 is on a distinguished road
http://www.stellamodels.net/catalog/...oducts_id=5071
might help gear changing ??
Daniel
Old 08-28-2010, 11:29 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Originally Posted by ddc333 View Post
Wow helical gears. Good thing they give you 3 pinions because tracking down replacement helical pinion would not be easy.
Old 08-28-2010, 12:02 PM
ihbuilder's Avatar
I don't know about it helping gear changing since the gears do not slide .
IHSteve
