Old 06-17-2011, 10:48 PM
Default Re: Something new to rc
Small world indeed Travis!
Yesterday, 1st tank (half a tank), I sprayed about 75ac of glyphasate/2-4-D to finnish out my chem fallow for the 1st pass, then I started to rinse out. I couldn't get the Roto Flush to work... it's suppose to be a simple half turn of one valve from Agitation to Roto Flush, but it just wouldn't come on. Boom press would bolt to 120psi & agitation went to zero... water flow was dead heading. Brand new machine... WTF?!
So I start pulling apart hoses and fittings till I found the problem....(drum roll)....
stuck in both sprinkler heads within the product tank looked like Milo?! HTF could that happen?! Some jackass at the factory thought he was being funny? This machine just come across the line last wk direct Indiana factory.
The Roto Flush now works perfectly! I can change chemical in a fraction of the time compared to the outdated pull type sprayer. Aint technology grand, more done with less effort.
Say Hi to your neighbors for me.
