Old 08-25-2010, 05:35 PM
oldboy's Avatar
oldboy oldboy is offline
oldboy is on a distinguished road
Default Re: I hate Tamiya three speeds
I Have found that you can bypass the gear shift if you run MFUs'
Just lock the gearbox in which gear you want and the mfu will change speed in the different gear positions example,
in 1st on transmitter revs are low
in 2nd on transmitter revs are medium
in 3rd on transmitter revs are high
so now I am locking my gearboxes in second and lettin the mfu do the work
saves on servos and linkage adjustments also it stops the gearbox from neutralizing
so that removes the problem of lost gears
Oldboy
Old 08-25-2010, 07:25 PM
TINY-TRUCKER TINY-TRUCKER is offline
Banned
TINY-TRUCKER is on a distinguished road
I had the same probs with 1st gear would work, then 2 nd would work then 3rd would be just not there so then i just lock it in 1st or 2nd gear & leave it cause i would not be driving it to far so yer. it piss me off as well.
Old 08-28-2010, 06:17 AM
ddc333 ddc333 is offline
ddc333 is on a distinguished road
http://www.stellamodels.net/catalog/...oducts_id=5071
might help gear changing ??
Daniel
Old 08-28-2010, 11:29 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Originally Posted by ddc333 View Post
Wow helical gears. Good thing they give you 3 pinions because tracking down replacement helical pinion would not be easy.
Old 08-28-2010, 12:02 PM
ihbuilder's Avatar
I don't know about it helping gear changing since the gears do not slide .
IHSteve
Old 08-28-2010, 01:55 PM
Juganought Juganought is offline
Juganought is on a distinguished road
I wont even bother fitting second servo's to my rigs now. Gearbox is locked in first, fast enough for me
Dont mess with ma trucks
Old 09-02-2010, 11:46 PM
sundance sundance is offline
sundance is on a distinguished road
I have 28 trucks and never had a problem with the 3 speed.
take it apart and start over again.
