Old 06-25-2011, 07:59 PM
ihbuilder's Avatar
Default Re: IH5070 Paystar 6X6 now a log truck
Joe my pump on the shelf to for a little . it looks out of proportion to the truck so I think I'm going to try to get a micro pump from the Germans for this 1 . I have timing pulleys for 4:1 reduction as a stacked unit I plan to get together for my TD40B and the big mack if the UMS pump will not work for it
thanks Brian
I'm pretty much shelving my projects till I get some customers caught up except for somethings I'll use as a trial run on the JD mill . Like the frame pieces for the pup for this truck .
if it does these right then I'll feel comfortable running drop deck frames .
Old 08-15-2011, 10:47 PM
ihbuilder's Avatar
last set of frames till I get a bunch of wheels out of my way
BTW : these have the ryco suspension built in
I'm trying to get these few frames out of the way before I tie up the mill on the 2nd op for WHEELS
