Hemi1966;
Your machining and photos are excellant. Keep up the good work. Ken |
No words to describe the workmanship, fit and finish. Awesome seems inadequate. You made the side-shift cylinder? Would you be willing to share you construction methods, especially what seals/o-rings and how they are arranged on the piston and head.
Thanks! Ken
Big iron is awesome! |
The most hardest task is to make the o-ring grooves to the cap that seals the piston rod. My side shift cylinder has 4 mm piston rod, so you need very small tool to cut the o-ring grooves with lathe. And of course the grooves MUST be in correct size, or they won´t hold the pressure The picture you see here is not the side shift cylinder, it´s one I made earlier, but it´s made the same way so you get the picture. ![]()
