Construction Equipment Tech Hydraulics, Electronics, General Engineering, ect in constr equip |
Hi Thanks for the reply, Please is it easy for you to tell me how to turn it up what skrew it is ect, like you ay I dont want to go to much 12 max but I think 9 is a little to slow the tube is what came with it as a kit from wedico I'm not sure of size 3 or 4mm, I'm really no tech type of guy I just really enjoy the playing & operating the the models, Thank you again for your help & time. Regards Jo
yes jo to turn it up look on the side of the pump and there is a black allen screw you need to undo this but be carefull as when you take this screw out the oil will come out you will have to lay the machine over so the screw is facing up when you take the black screw out behind it there is a tork screw i think #6 and if you turn it clockwise you will turn up pressure counterclockwise lower pressure just turn clockwise 1/4 turn and put black screw back in and check your pressure and tighten the tork screw to pressure you want also if your machine is older one it probably has 1.5mm id hose newer ones have 2.5mm id hose that will make it slow too thanks neil
